Add a protected VLAN on the ERPS ring. This is a data VLAN that ERPS will protect.
| ring-name | Alphanumeric string that identifies the ERPS ring. |
| vlan_name | Alphanumeric string identifying the data VLAN to be added that ERPS will protect. This can be a VLAN, SVLAN, BVLAN or VMAN. |
N/A.
Use this command to add a protected data VLAN on the ERPS ring. This VLAN will be protected by ERPS, and it can be a VLAN, SVLAN, BVLAN or VMAN.
The SVLAN-BVLAN combination cannot both be added to the same ring or sub-ring.The following command adds a protected VLAN named “vlan10” to an ERPS ring named “ring1”:
configure erps ring1 add protected vlan vlan10
This command was first available in ExtremeXOS 15.1.
